Hi all.
Short version:
I have a combi boiler which is losing pressure.
Long version:
Boiler was losing pressure since around June/July. Put a bucket under the overflow and worked out that we were losing 1/2 pint per day.
Boiler was serviced and fitted a new pressure relief valve on 11th September, since when I've re-pressurised the system twice.
We're now losing about 1.25 pints per week down the boiler overflow (plus evaporation), and it's dropping from 1.5 to 0.8 in the same time period. It takes 27 seconds to fill it back up, which would seem like more than we're catching in the overflow bucket, unless the feed is very slow.
To give an idea of size, There are 14 radiators on the system.
(Full disclosure: I did replace and re-plumb a radiator back in November, but pressure tested everything and left the floor up for a few days to check it was OK. We've no obvious leaks coming through the ceilings anywhere.)
Haven't bled the system through in a couple of months. Going to do that later.
The heating has not been on. Just hot water.
I'm stumped as to the cause of the pressure loss, any ideas?
Short version:
Long version:
