Low Pitched slate roof is leaking - Possible solutions
20 Dec 2014
Yorkshire
I've had an L shaped extension built around my house and the roof has a 9-10 degree pitch
I've had leaks coming through and had the work done again both times OSB boarded
counter battens and also double up on breathable membrane. with the slates having a
bigger overlap. This was in December 2014 I'm still waiting to move in and have had many
problems. The builder has re-roofed this section and used permavent easy slate strips
this has got rid of most of the leaks but I still notice damp patches during heavy rain.
One possible solution ive been thinking and been told about is to strip down to the OSB
board and use torch on felt underlay a high quality one like Icopal Torch Safe T.A
and then felt over with Icopal tecnatorch sand. Then counterbatten and use torch on felt
over the vertical battens for further protection and then batten again and fix the sales again as
just for aesthetics the primary roof would be the torch on felt.
Would this help. This has been a big stress for me. Any advice appreciated.
3 Sep 2006
West Mids
You can have slates, but you must first cover it as a felt/flat roof to provide the waterproofing, and then batten and counterbatten for your slates which will be realy just for aesthetics.
Care needs to be taken at the eaves or verge to prevent it looking a bit crap with an odd-looking deep fascia
20 Dec 2014
Yorkshire
Thanks for your help. Yea the slate is just for aesthetics I'm thinking two layers of Icopal torch safe TA underlay. And then tecnatorch sbs layer. I've been told to felt over the vertical counter battens is this the way to go?
3 Sep 2006
West Mids
No. Felt the roof as a normal flat roof. Fit minimum 25mm battens running from abutment to eaves at 600 or 450mm centres. Fit breather membrane and slate battens as normal.
Any nails through the flat roof felt self seal by the bitumen. The roofer can apply a sealant of he wants to.
20 Dec 2014
Yorkshire
On which layer would you place breathable membrane?
2 Feb 2006
Staffordshire
The whole flat roof below a fake tiled roof all seems like a complete bodge to me. Like Freddie, I can't get my head around building a flat roof then whacking a load of fixings through it. Just plain wrong. Plus, the shallow pitch looks alien regarding anything tiles.
Get a flat roof material on it (nowt else) from the outset.
