    Dismiss Notice
Lukewarm bath shower mixer
Discussion in 'Plumbing and Central Heating' started by MugabesDeadCat, 13 Jul 2013.
  1. MugabesDeadCat
    MugabesDeadCat
    18 Oct 2009
    89
    Thanks Received:
    Tyne and Wear
    Country:
    The thermostatic bath shower mixer tap, has, all of a sudden started delivering only lukewarm water. This morning, and for the six months it's been installed it's been fine. Now though, it'll give you full on cold, but as you turn up the temperature dial, it gets warm then no hotter. All other taps give hot water. Any ideas what the problem is?
  2. Sponsored Links
  3. Charnwood
    Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
    Blockd filter?
  4. MugabesDeadCat
    MugabesDeadCat
    18 Oct 2009
    89
    Thanks Received:
    Tyne and Wear
    Country:
    Well, I took the tap off (it's a bar mixer mounted on deck pillars), to my surprise, the filter is no more! It's rusted away! I thought they'd be stainless steel? Anyway, I removed the mixer cartridge from the tap to check for blockages, but couldn't see any evidence. Upon reassembling it it's still the same. :(
  5. Charnwood
    Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
    Next, cartridge, although at 6 months old that should be OK.
    Is it thermostatic on both bath and shower. Some aren't.
    Make and model?
  6. MugabesDeadCat
    MugabesDeadCat
    18 Oct 2009
    89
    Thanks Received:
    Tyne and Wear
    Country:
    It's a cheap ebay affair. :oops:
    www.ebay.co.uk/itm/200750279180
    Kinda thinking you get what you pay for! I've taken the temperature knob off, removed the black plastic stop and turned it up as hot as it will go, but it is still only lukewarm.
  7. Charnwood
    Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
