EDIT: before reading the below, we need to know how that ceiling rose is wired. It doesn't look right.
Where was the link? And that switch wouldn't have worked wired like that (I think) anyway, even with the link.
What you have there is ONE live feed. This is likely to be one of the reds.
One of the blacks (with the red wire above) is the switched live feed to your kitchen light.
These 2 need to be connected to your new switch, in Com and L1, either way around.
The other red and black pair to the other switch - connect ONE of these to the permenant live feed in the switch. The other wire, terminate in a piece of spare terminal block.
This SHOULD work. You cant really go wrong anyway, when you've found the permenant live wire.
hi,the four wires in the switch were not wired like that,i just put them one in each hole to keep them safe (hopefully)
I cant remember where the other "link" wire went.
I will have another go with your advice in the morning regarding the kitchen light...still not sure what to do about the ceiling rose though.what do you all think?thanks,kez..x
