I have recently had a Main Eco Compact 30w after my Vaillant ecotec 837 plus failed after 11 years.
My combi and main sink tap are at total opposite sides off the house so when I draw hot water it takes an absolute age to get from A to B.
I've altered the flow of the water but it's the same. My water can be like warm for over 2 minutes plus before it gets to hot which is you can put your hand under it but it can be uncomfortable.
I'm scabby eyed going over the manual but I can't see anything regarding pre heat so I'm not sure on that.
What is the max temp you can set the water to on the combi ?. When I spin the dial it says 60. With my Vaillant I would aim for 62-63 in winter and lower it when needed if too hot in the summer.
I use a timer thermostat ESRTP4RF+ for the heating so can anyone give me any tips as the manual is very sparce to say the least.
