Hi All,
I am building an extension and need to re-route one of the connections to an IC.
I have a Brett Martin 450mm IC and it looks like this connection that will be removed is the main inlet. This would leave a branch connection and the exit only.
I know that this will likely cause backing up as there will be no main flow, is there a way around this without digging out the chamber and turning it so the inlet is used again (chamber goes down 1.5 metres!)
Many thanks in advance,
Bob
Bob
