Hello All,
I'm considering replacing 4x radiators and associated 8mm microbore pipeage with 15mm to each rad from the 22mm flow/return. This is currently done through an 8mm manifold at each end (4 out and 4 back in).
Now when I put my 15mm tubes in to each rad and back I'm looking to do this by contructing a manifold using copper soldered 22 x 15 x 22mm reducing T's and joing these together in two groups of four.
I'm doing this as I have an abundance of these fittings and preformed manifolds can be expensive.
Apart from the extra effort, can anyone see any problems with this?
