Manufacturing IP rated products
27 Sep 2004
I am in the process of designing my own lighting products for manufacture by myself. I am going to be CE marking and testing myself, but wondered if anyone has any knowledge or done something similar about IP ratings? For example a light fitting to be used outside needs say IPX4, can the manufacturer carry out these tests themselves and document evidence, or does it need to be sent off to a lab and have another company do the testing? I have found details on the sequence and requirements of the tests but need more information but cant find it!
Any help appreciated. Thanks
Yes, you can do the test yourself, provided you record the test details and results in your technical file. I'm not sure why you'd want to though, since the test apparatus specified in BS EN60529 is fairly complex, and you won't be using it enough to justify the cost.
Remember that each IP rating implies that the tests have been performed for the lower ratings, i.e. before claiming IPX4 you will test for X3, X2.
