Hello all, seen similar posts elsewhere but not quite the same so thought I'd ask it. I've bought a ceiling pendant light which requires a max 60w e27 bulb. Unsurprisingly, this isn't bright enough. Can anyone suggest what the highest rated low energy bulb equivalent that I could use is (bearing in mind it needs to fit the same "connection")? (i.e. could I use a 100w or 200w low energy bulb?) I understand the main problem is the heat rather than the wattage....
If it helps re the heat aspect, the bulb is contained within a larger globe with various spaced sheets of aluminium (it is the sliced plate pendant light from Dwell).
Any help would be much appreciated! Marc
