MCB tripping for no apparent reason
I think it may be electrician time to be honest, for your safety.
the RCD refused to trip even if I deliberately pushed the RCD tester
Are you saying the test button on the RCD does not work anymore?
Do I set it to the right where there is the letter A with some squiggly lines beside it? If so what setting 200u, 2000u, 20m or 200m?
I'm not a sparky, but couldn't help but notice that the OP proposes to use the 'A' range on his meter - which is for measuring current, not resistance.
You must not do this - at least in the capacity in which you describe - presumably connecting the probes right across the circuit causing a dead short.
You are looking for the resistance (ohm) scale on the meter and you must turn the power off before measuring.
If you are looking for a low resistance it should be pretty close to 0 ohms.
Sorry Sherlock, The RCD would not reset but the MCB had stopped tripping out.
The sparky was on his day off and the maintenance manager gave it to me. I will read the info you have sort carefully.
Since I disconnected the dodgy spur wire from the circuit, there has been no more tripping..... so fingers crossed!
I really appreciate your assistance and your patience!
Cheers
KennyB
Please do not play around with that tester - if you don't even know the difference between current, resistance and voltage you risk a large bang, damage to your installation, damage to the tester, and damage to yourself.
