Gasman1015 said:I recall reading somewhere 3 metres, cannot remember where at the moment, so don't quote me on it.
do you mean the meter? having a cu outside doesn't sound too good.Desie said:3 metres sounds okay. The cU is in the cellar and the DNO are coming to move it to the outside of the house.
I know, but do they still do this? it sounds a bit backwards if they do. And i certainly wouldnt have a CU MOVED from inside to outside!securespark said:I know countless 100's that are installed in an extenal meter cabinet...
crafty1289 said:I know, but do they still do this? it sounds a bit backwards if they do. And i certainly wouldnt have a CU MOVED from inside to outside!securespark said:I know countless 100's that are installed in an extenal meter cabinet...
We aren't concerned with the size of the cables, its the TYPE of cable that I think is the issue. Obviously having single cores flying about the place with no protection (other than a slow-blow (in my limited experience) 100A fuse) is not a good idea for long runs. So most DNOs will demand Armoured cable for runs above 2-3 metres, so if someone cuts a live, they cut the others and it will blow the fuse immediately. The switchfuse is still required, and is usually used to terminate the SWA onto.WSDLTD said:there is no maximum length now that they have been uprated to 25mm there used to be 2 metre max or u had to have a isolator in line
