Miele W828 off centre drum
26 May 2021
Portugal
Hi, I’m new to this forum, maybe I can get some advice from the experts on this. I have a Miele W828 washing machine that works fine except for a loud noise while spinning. The drum bumps on the glass at two opposite sides. First I replaced the dampers that had no oil in them but the problem persisted, although a little better. When I took the drum out I noticed that the inner drum rotates a bit off centre. So I extracted the inner drum I saw that the axle looks fine as well as the bearings, there is no slack. However, the inner star-like structure that holds the axle has some important corrosion. Do you think it is worth the money and the trouble to try to save this machine?
Our machine did the same thing after 9 years 10 months. Just in the guarantee period!
machine had done a little over 2000 washes.
Miele did the change and the machine has continued working for another 10 years with no sign of breaking again.
if you can get a new drum then yes, it's worthwhile.
