- Joined
- 22 Jan 2007
- Messages
- 24,428
- Reaction score
- 3,655
- Country
It wasn't caused by humans in the past, it is now.The difference, is what it has always been, sometimes little different, sometimes a rapid, and sudden change.
Really? The only comparable rate of change I've heard of is meteor strikes or supervolcanos. When are you thinking of?The difference, is what it has always been, sometimes little different, sometimes a rapid, and sudden change.
We go to the higher up, glacier resorts, so we're OK. I did once ski on grass in Morzine,a few years ago. Weirdly, Morzine had more snow than ever last season...Not for you because you wont have any snow to slide down
Nonsense.The difference, is what it has always been
Weirdly, Morzine had more snow than ever last season...![]()
Don't upset himThere was the Younger Dryas event.
Interesting, closer to the supervolcano though as it's thought that a lake larger than most countries suddenly dumped itself into the Atlantic Ocean. It also wasn't a global warming or cooling event as whole the Northern hemisphere got cooler the southern hemisphere got hotter.There was the Younger Dryas event.
Actually, it's the opposite.CLIMATE DENIER **CLIMATE DENIER***
If its all happened in the past, and would happen regardless of us being here or not then what difference does it make?It wasn't caused by humans in the past, it is now.
If it can be avoided (the extinction of humans) then it's natural to steer towards that goal.If its all happened in the past, and would happen regardless of us being here or not then what difference does it make?
If that's what you think then you must also know that your existence is a part of the problem.If it can be avoided (the extinction of humans) then it's natural to steer towards that goal.
Correct. It's why I didn't vote for Brexit and plan to leave this mortal coil, come what may.If that's what you think then you must also know that your existence is a part of the problem.
Ah, well if it is all for your own entertainment then hats off to you.Correct. It's why I didn't vote for Brexit and plan to leave this mortal coil, come what may.
One does what one can.
