Hello All,
Currently in the early stages of sorting out a side extension and I would like some clarification with regards to an outside inspection chamber.
I have a mini inspection chamber which will be covered by block and beam flooring for the new extension. The chamber is connected to our middle floor bathroom waste and ground floor kitchen waste pipes which are all boxed in internally. Single pipe entering and exiting the chamber.
I understand I need to keep some sort of access to this and I have no other suitable place that is can be moved to.
I was curious as to if it was deemed OK with building regulations to replace the inspection chamber with a straight through pipe and install a rodding access point at the bottom of the internal soil pipe with an access cover on the internal wall to this point?
I am aware I can get an internal inspection cover but I would prefer to avoid unsightly cuts the flooring we have planned in the new living space.
Thoughts appreciated.
