I've searched on the forum, and found a few threads dealing with this, but still need a bit of assistance.
So, the shower started overheating a few weeks ago. It's quite old now, probably 7-8 years, but it's worked fine all this time (except for the whining noise, which was there from the beginning, but never seemed to affect anything, and we got used to it).
It starts off fine, and warms up, but soon an overheat light comes on, it then goes cold for between 10-30 seconds, then warms up again, is ok for a minute or so, then the light comes on again, and it repeats this cycle. As the weather's warmed up, it's now doing it more and more.
I opened it up and checked the TCO with a multimeter and it's got continuity, as I expected, as it's not cold all the time. There were some slightly encrusted bits on top of the heater tank, see pictures, not sure if this is normal.
I took off the hose and the shower head and tested it without those, suspecting limescale, and it seemed to run hot for a bit longer, but then still overheated eventually. I descaled the showerhead not that long ago, and it doesn't look bad, but I'm now descaling it again, just in case (but I don't think that's where the issue is). The hose I'm a little suspicious about, as it's a replacement, it's this one. I was thinking could it be the culprit, if the bore is slightly smaller than the original, but I'm not sure, because I've installed it in September last year, and everything was fine until the weather warmed up, and it started playing up a few weeks ago.
The water pressure seems fine, and I can't see any difference from normal.
The flow regulator seems fine too, as the flow progressively changes as you turn the main temperature dial.
Can anyone suggest what else I should try or check, in order to pinpoint the issue.
Many thanks!
Many thanks!
