- Joined
- 11 Jan 2004
- Messages
- 46,561
- Reaction score
- 3,843
- Country
For my next trick, I have to remove steering column surround and replace the wiper stalk.
I have got a pair of sun visors as one is busted (repaired with sparkies tape) and the other is following it.
The rear wash is still blocked. I have ordered a can of air and I'll disconnect the rear pipe under the bonnet and give it several blasts through from the rear washer jet. If this doesn't work, I'll have to order a new jet - can't find any OE on ebay - and work out how to get the old one off....
Gotta polish the headlights which are fogging up, that's a bit of a fag.
There are some rubbing strips on the front bumper that are very tatty, but a pair on ebay (second hand) are >£60, so sack that!
There are some rubber stops on the inside of the two front doors that are missing; can't find those on ebay...
And the o/s wiper is hitting the windscreen surround. Have removed and repositioned the wiper arm on the spindle, but it does not cure the issue. There is a little wear in the motor that allows the arms to move a little: perhaps it is this free play that is allowing the arms excess movement which is why it is hitting the surround. Hoping that it does not become terminal - I don't fancy changing the wiper motor. Done it before on a Rover 820 and it was a real fag!
After sorting that lot and a service (gotta check the cambelt.....
), we should be good to go.
