the cable for my lighting circuits is 1mm at the consumer unit, however at some point upstairs it turns into 1.5mm cable...
is it nessisary to replace the 1mm cable [i really hope not!!].
As doing both lighting circuits in 1mm cable [its only a small house, 4 rooms on each floor] should be OK, then I assume that having a higher rated cable present for part of the circuit should not be a problem...especially as the cable at the consumer unit is the lower rated of the two so no misleading if someone should ever decide to extend one of the circuits.
any thoughts?
any thoughts?
