Mock tudor beams removal
17 Aug 2021
Hi guys.
Wondering if anyone can shed some thoughts on removing mock tudor beams? Surprisingly, there is very little info on this online and where forums threads have started, the responses are overwhelmingly based on 'don't do it! spruce it up!' its got character'.
I have had some quotes but tbh I haven't felt very reassured with their outlooks.
Has anyone got any experience in this?
Is it possible to remove them and fill with render in a 'proper' way so you don't get cracking and it eventually all looking horrible down the line?
Also worried about the corners when those beams are removed. Does it start chipping etc..?
Much thanks
Sus
22 Jul 2016
I can't really help but are they interior or exterior?
I am presuming exterior ?
I know from seeing a local house being refurbed that theirs were just timbers fixed to the brick wall then rendered between. Presumably you want to remove and fill in the slots that are created?
17 Aug 2021
Yea exterior. Want to remove them and fill in with render. But I would assume normal sand/cement will not adhere well and there must be some new tech way of doing things so that it fills in well.
15 Sep 2017
S. Uplands
sounds to me like you will end up with a house which looks likes its had mock beams removed
I think you would have to chip off the render and re-do it completely
