Is it just me that finds the modern car a nightmare to work on, i don't specifically mean because of all the electronic technology, but more about the way things have been built.
I've just spent hours removing a cylinder head on a Meriva, struggled for ages getting the exhaust manifold off, bolts which should have a 10mm head but corroded due to heat, end up being about 8.5mm and not a chance you can grip them, "TORX" type bolts in the exhaust support bracket which have nearly disintegrated before you've put a spanner anywhere near them.
I've been involved in the motor trade for 31 years, and it never used to be the case that you needed a hammer and chisel and an angle grinder to remove a cylinder head from a 5 year old car or truck
Another pet hate is all the plastic clips and fittings which become brittle with age and seem to snap if you as much as look at them.
From my experience it doesn't seem to be just Vauxhalls that suffer from these problems, i suppose its just part of the demand for cheap mass produced cars
