terryplumb
could I ask one more quick question if I happen to fit new parts sooner rather than later...
The white bit which screws into the plastic nut under cistern ....
When originally fitting this I had to cut it down a bit. This is because the length of the part seemed to be longer than the actual gap between close coupled units. Obviously I cut it after fitting , otherwise it would be harder to start the thread. Please confirm that this makes absolutely no difference to whats going on above.
Im thinking that the seal that moves up then down again, although I have replaced this,...the thing it comes down on ie white plastic rim maybe that is not 100% smooth.
