- Joined
- 13 Dec 2019
- Messages
- 79
- Reaction score
- 0
- Country
Evening,
I am looking to make some monkey bars for my daughter who is 11. I am going for a low key pair of monkey bars like the ones in picture 1, however I intend to use extra support as in picture 2.
I had 2 questions I'd like to ask:
1. I assume for attaching the vertical run to the horizontals I should use coach bolts/screws - which should I use?
2. The height of the horizontal run for the monkey bars I'd like to be around 2100mm, so will use 3000mm length, cut to 2800mm then put 700mm in the ground.......Or is 600mm enough?
It will just be my daughter and maybe the odd friend using it. No adult use.
Thks
Thks
