- Joined
- 30 Aug 2005
- Messages
- 36
- Reaction score
- 0
- Country
Hi all
I'm looking for the best solution to allow me to mount an LED and a soundbar to a solid brick wall. I've seen lots of posts here about channeling, fused spurs etc and these all seem to make sense ... but in my case I don't have equipment yet so not sure it works for me as I don't know where to place things on the wall and can't wire in the devices.
We have builders and electricians round - first fix almost done, plasterboarding from this week so don't have much time to plan and not yet in a position to purchase the TV or the soundbar. I wanted to understand what my best options are with regards to prepping for when I do get these bought.
I have lots of questions!
1) AV cabling
For AV (2 x HDMI, Coax, RJ45, optical) I'm thinking of having a channel cut into the wall behind the TV and have it run all the way down the wall to my AV corner. I'll install a brush plate (single/double) at both ends of the channel to neaten things up. I think I will run the cabling in now .. i.e. even before purchasing the equipment.
Q: Should I use some sort of trunking for these or should I run the AV cables directly in the wall?
2) Power for TV
I'm planning to have a 2 gang socket installed directly behind the TV area.
For the TV this will plug directly into one socket and the other end into the TV - should be easy enough and have no cables showing.
Q: As a rule of thumb, any advice on where to position the 2 gang? I'm thinking I should place this bottom left corner of the TV when viewing from the front to allow for clearance of the wall mount fittings?
3) Power for Soundbar
I plan to have a channel cut directly below the 2 gang socket and have this run halfway down the wall. I'd get this plaster boarded till ready.
When I have the soundbar, I'd carefully (!) create two cut outs in the plasterboard to expose the prepared channel: one cut out directly underneath the 2 gang socket area and one in the position where the soundbar will be placed. I'd then plug in the soundbar to the spare socket behind the TV and feed the other end of the cable through the cut out below and out of the cut out where the soundbar is positioned. I can then connect it up. Again - no wires showing.
Q: Overall, does this sound like a reasonable approach?
Q: I'm also a little concerned that the TV plug and soundbar plug would sit too proud and force the TV to stick out (I wanted a slim wall mount stand with a tilt option).
I'm looking for a simple and neat solution that is flexible enough so many thanks for your time and advice !
Many thanks for your time and views on this.
1) AV cabling
2) Power for TV
