Move and enlarge window in brick wall
6 Feb 2009
Yorkshire
Hello!
Just been thinking about room dimensions and where to put my new partition walls - and noticed that I kept saying "if only that window was 8" to the right"... so got talking about how easy that would be!
It's about an 80cm wide ground floor window with a relatively modern lintel above it (it's not the original for sure) thats tied into blockwork (breeze blocks).
We have recently exposed the lintel whilst replacing the plasterboard. Just wondering what type of job it might be - how pricey it might be etc.
Ideally - we would like to move the window 8" to one side - and make it 50cm wider.
Costs that I would imagine:
remove block and brickwork where I want new window to go (labour)
8" of blockwork and bricks on the side (lab + mat) - finished to existing standard
cost to prop structure whilst removing existing lintel (lab + hire)
cost of lintel (original length plus extra 50cm) - would I need detailed calcs or could the costs of over-engineering on the old lintel's specs by say 100% suit?
cost of new window and cost for fitting
making good with internal decs
Do you know if building control would need to get involved? I can't figure out if I would need planning permission either.
It sounds like I need to get some proper builders in - but wondered if anyone could offer any ball-park figures for cost, or give me an idea of how straight-forward a job it is (or isn't!)
Whitling2k
