We have UK Power Networks ... (after much delay (we placed the order back in December) and faffing with council street permits, Covid 19, Sunday working requirements - even though the streets are deserted etc etc) .....a date for installing a new supply, and moving an existing supply.
I am told the Utility company is responsible for moving the meter only and not the DNO (UK PN will not move the existing meter).
Currently with Covid we cannot get anyone to come move/install a meter.
Am I correct to say that normally the meter should be next to the head, and the CU no more than 2 mts from the meter (unless a 100a DP isolator is installed).
Will the DNO connect the moved supply to the existing meter, even if they are several meters apart, just temporarily, whilst we wait until Utilities are able to install/move new meters (which will be in a slightly different location).
When new meters are installed, does the Utility company break the crimps and use the DNO's isolator, so they can connect up the mete.
What is the situation if my spark cannot be present when meters are changed ... he is currently stuck abroad.
Should I be concerned about being left without a connected supply (at least just one) when UKPNM come ?.
