Moving a wall light up about 12 inches.
7 Jan 2014
West Glamorgan
My conservatory has wall lights either side of the opening from the house, with cable behind dot n dab drywall.
I may need to raise them up a bit (to accommodate a vertical radiator one side of the opening).
They are fed from below, from socket circuit via a switched fused unit.
Can I extend the cable? If yes, how? Choc blocs?
Or should i try and run full length cables down to the fuse? I've kinda answered my own question! (But are choc blocs a respectable, legal fix?)
I feel quite able to do this work- is it notifiable. No other changes are planned. Thanks.
CG
Edit: Soon as I submitted, several similar questions were shown at the bottom of the page! Choc blocs were seen as good by one, and bad by another poster, as was crimping! Help!
It's not notifiable.
If at all possible, replace the cable rather than extend it.
If you do have to extend it, choc-block is not acceptable - use either a maintenance-free JB or crimps.
Is the circuit RCD protected?
