Moving Cooker Control Unit?
31 Oct 2009
Cambridgeshire
I'm currently fitting a new kitchen and it turns out I'll need to move the existing CCU another 18", but I'm unsure as to how best do this.
Can anyone advise? :?
Can you not just replace the cable from the cooker switch to the ccu - one less jb?
Sometimes your lucky and the there is a bit of room under the backbox.
Once below the kitchen worktop it doesn't matter whether its buried or surface mounted.
The cable's been buried from the original fit-out, are you suggesting pulling the cable out and reinserting it with additional length (assuming it's been covered in capping), or breaking the plaster first?
Edit: I can't do that as there are two feeds within the CCU, one from the CO and the other from the CU. That means a JB must be the only practical option.. :?
