A
Alarm
Better off not using silly granite. What's the point when you have to cover it up to make it useful?
As with any surface,you protect it.
Or do you sling plates directly onto glass.? (Told you he could not prove it
Only if spilt on it. In a cup its fine.
And you said Coffee before.
Which one is it.
Can you prove the thermal deficiency with china in proximity with granite?
(Bet he cannot)![]()
Sore ass time again![]()
Hi All,
I'm having some granite installed in a couple of weeks time and the quote had the weight of each piece estimated next to it. One of the pieces is down as 270kg, although it is a curved piece so has corners cut off and wont utilise all of the slab it's cut from, so I'd estimate maybe 230kg. Even so, how on earth will the fitters get that in and up on the units? Are they generally just really strong guys or do they have lifting equipment?
I'm worried about my new limestone floor I've just fitted!
Cheers,
7d
Two blokes can lift it without a problem. I bench 140kg!!
Is that what you spent your time in prison doing. Building muscles.![]()
Heaviest weight I ever lifted was a volkswagon jetta. Rolled it over on its roof and then back unto its wheels with my mate inside and then jumped inside and we drove off. Its quite a party piece.![]()
What a dope you are. Granite is cold and absorbs heat from the cup. No wonder you are jobless.![]()
What kind of units are you sitting it on? Will they take that weight?
Dunno why you want granite anyway - it's horrible cold stuff.
