Multifuel Stove in Conservatory through polycarb roof - doable
dont forget you need to get building control involved before you start to go that route
Yes I will contact all necessary bodies & find out the cost of getting it inspected & certified before starting any work (this actually will be the deciding factor whether I do it or not)
Looks like I will have to forget it - I have just realised there is no way I can position the stove that maintains the minimum required distance of 600mm to the PVC widow frame & ledge on the Right hand side.
Unless there is any way out of this?, if not looks like project abandoned
Pricier ,but some of the small woodwarms are down to 152mm back and sides and will sit on a 12mm projected hearth.
Lateral support above the roof still seems to be the most difficult part
way too expensive - I'm not actually going to spend anymore money on a new stove, the idea was 100% based on being able to fit the new Stove I already have, If I can't do this I will forget the idea.
I may look to have it installed in my living room, but that is more involved as I would need a twin wall flue installing to replace the current flexible gas flue that is already in, not sure what the cost of that would be.
I will start a fresh new job thread if I need more help & info on this
Typically looking at about £1500ish to get a chimney lined and stove connected
