Hi my bedroom has got 3 windows; 1 faces east, rest faces south. above there is a loft. bedroom is 14sq meters, brick walls, double glassing windows, as We have a new born we can not make a draught , so I tried to put the second layer of insulation in the loft ,only above that bedroom, We tried air con, which resulted all of us getting a bad cold, I tried covering the windows facing south with kind of a foil, to reflect sun heat-but the problem still there.
even when the sun goes down in a late evening temperature stands 27 degree, after making a draught it drops by 1 degree, but when we close the windows in 15 minutes it is back to 27 , outside temp at that time is max 18.
on other hand on one day there was no sun, only in the afternoon sun showed up for 2 hours only and then the room temp risen up.
and I'm not sure where is the heat coming from, from a loft or from through the windows, the next step I am going to try is window film to reflect sun heat, but would it work? has anyone got an idea, how to make my bedroom cooler? many thanks
