My Boss asked if the cables could last a few more days...!!
14 May 2008
Durham
just some prime examples of what overheating and poor cooling can achieve... and to top it off my boss and his short arms deep pockets motive asked if they could last bit longer as the budget was bit low...
what sort of cable, and what did it feed?
it "was" a 16mm cable that tailed from the 440v bus bar to the switch for a 3 phase induction fan that we use to induce airflow around our site.
Looks more like a loose connection to me or a hot busbar with inappropriate insulation on the cable.
if you look carefully you can see where it melted to the other cable at the back..
the cabinet is v.hot inside and it don't help that our cooling system has been trout for last 9 months.... (we leave it ajar with a portable air con system blowing air in that direction.)
no the terminals were very tight and secure and the insulation crumbled away near the connection when i removed it. however the bit further up was already gone.
im not really that fussed what caused it as a dam good fire would really sort the inapt "cost cutting" management out! :)
