The hole-placement is nothing to do with electricity - it's the reduction in strength of the joists that's as stake. If there are holes there already, even if they're in the wrong place, I can assure you that drilling new ones won't make the joists stronger!lorraine said:4. We are about to install an upstairs ring, the problem lies in the cable routing. the holes in the joists that the previous circuit used (radial circuit) aren't between 25 and 40% of the beam length. Would it be okay to use these holes are will the council ask me to drill holes in the correct place? I figure having two holes is worse than having one!![]()
If there are holes you can use, use them. If not, drill the new ones in the right areas of the woodwork.
Cheers,
Howard
