Nail ALMOST put through central heating pipe. Please help!!
If it's in 15mm copper then the easiest answer for the OP would be a 15mm comp repair coupling. This is a slip coupling about 3 - 4" long and you won't have to worry about all the water being removed.
I Must be missing something Oilman as i didn`t mention pipe i used the word RADS.
Perhaps you should stick to the OP's original question then, and not hijack the post. :D
