Need advice repositioning undersink pipe
Discussion in 'Plumbing and Central Heating' started by OM2, 30 Jun 2021.
  1. OM2
    OM2
    18 Jan 2007
    816
    Thanks Received:
    3
    Country:
    I need to replace a broken swing bin under the kitchen sink.
    I bought one from screwfix - but the bin won't fit because of one of the pipes from the sink.
    I wanted to know if it would be a good idea to reposition the pipe?
    See below for a pic of the part that gets in the way.
    [​IMG]
    See below for a very very rough drawing I made using Paint! That shows how I can maybe try to reposition the piping?
    [​IMG]
    QUESTION: is it absolutely necessary to have the elbow bend?
    The pipe is coming from the mini side sink.
    Why can't I just ink it to the main kitchen sink - that has an elbow bend already?
    Thanks.
  2. Sponsored Links
  3. just pumps
    just pumps
    24 May 2016
    3,078
    Thanks Received:
    519
    Country:
  4. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,471
    Thanks Received:
    1,762
    Northamptonshire
    Country:
  5. OM2
    OM2
    18 Jan 2007
    816
    Thanks Received:
    3
    Country:
    Thanks for the replies guys.
    I don't think that would work. Not enough room I don't think.
    The cost of the pipes would be quite expensive.
    + i would need to spend time fitting.
    It might be better off me making a swing bin!
    I looked up on youtube - nothing :(
  6. Madrab
    Madrab
    4 Oct 2012
    8,569
    Thanks Received:
    2,482
    East Renfrewshire
    Country:
    You could make a bespoke waste for it, using a 40mm female waste adapting elbow then some 40mm waste pipe and swept elbows to connect to the other trap. You would want to use solvent weld, apart from the initial connection to the adapter of course to minimise the risk of anything leaking later down the line.
    [​IMG]
    • Thanks Thanks x 1
    • Like Like x 1
  7. just pumps
    just pumps
    24 May 2016
    3,078
    Thanks Received:
    519
    Country:
    https://www.screwfix.com/p/floplast-solvent-weld-waste-pipe-white-40mm-x-3m/44310#_=p
    £4 for pipe if required, spend sometime fitting? Less than an hour.
    • Thanks Thanks x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
