Need help to change to change bathroom ceiling light!
26 Nov 2014
Birmingham
Hi
My apologies for asking such a noob questions. I am making some changes in the house and wanted help to change the bathroom ceiling light.
I have removed the top of my old bathroom light and the connections appear a touch different from the new light. I assumed it was just a case of attaching the correct coloured wires to each end! Can any one help me to figure out where the wires have to be connected!
I have enclosed five images - existing baseplate connection, existing light connection, new light base plate,main plate of new light and the instruction leaflet.
Any help most welcome.
Megan
Red to Brown
Black to Blue
Greeen/yellow to centre connector.
It is very poor of them to show the connector in the instructions the other way round.
However, you will need to do something about the connectors at the ceiling to get them out of the way.
You could just make the hole bigger and push them into the ceiling but it would be preferable to use one of these -
https://www.tlc-direct.co.uk/Produc...IahbASfSzDMIqAcf92n8fjjeztGz8br3M2hoCgdbw_wcB
or if the wires will come out of the ceiling farther then redo the connections below the new top fitting.
Red to Brown
Black to Blue
https://www.tlc-direct.co.uk/Products/ASJ501.html?source=adwords&kw=_inurl:www.tlc-direct.co.uk/products/&gclid=CjwKEAjw1MSvBRDj2IyP-o7PygsSJAC_6zod4C4ElQmIahbASfSzDMIqAcf92n8fjjeztGz8br3M2hoCgdbw_wcB
Thanks EFLImpudence! What do i do about the yellow wire connector in image 3 (baseplate of new connection)
Do I need to disconnect the wires at the ceiling or can I unscrew them at the connection of the old light(image 2) where all three wires are connected and attach them to the connector on new light (image 4)?
megan
Just leave it. It connects the two pieces together.
It depends. As I wrote, if all the wires are long enough you can pull them down (no force).
If not then you will have to connect as above.
Thanks so much EFLImpudence. I'll have ago either tonight or by the weekend. One last question though, do I need to go to the loft to check where to anchor the baseplate for the 3 screws? That would be a bummer! Can I use something like these or anyway to anchor the slightly heavy baseplate on the ceiling plaster?
http://www.amazon.co.uk/HEAVY-PLAST...1-2&keywords=Hollow+Wall+Anchor+Cavity+Fixing
Not essential.
Likely the hole in the ceiling is (or will be) big enough for you to tell.
Feel around with a pencil.
Yes, they are best.
Cheaper tool here: http://www.toolstation.com/shop/p96740
They spread out so (mind you do not trap a wire and) cannot be placed right next to joists to which your present bracket may be screwed.
If so, you can use that for at least one of the screws.
Just a quick note to thank EFLImpudence:). I managed to successfully change the bulb. Although another ceiling light in another room has short-circuited!I guess my earthing wire in the light I replaced must be wrong. I'll have a look at it after work. But thanks so much for the help.
What do you mean by "short-circuited"?
Why do you "guess" that?
I'm not saying this to be funny or anything, but you had a light with terminals marked L, N & earth to replace with another one marked L, N & earth, and you didn't know what to do. You've now got a fault on another light and are guessing it's something it cannot be to do with the wiring you did on the new light.
It really isn't safe for you to be doing electrical work when you understand so little about it - you ought to spend a bit of time curled up with the Collins or Haynes home electrics books and/or look at info on the Internet. And in the meantime get an electrician to find and fix the fault you have.
