Hi guys I need to source some fittings for a gas guy to come and connect and leak test afterwards. It's only a 10cm stretch between 2 gas pipes where one of the ends looks like this:
And the other end looks like this:
I believe they are 28mm fittings.
Do I need any type of special fiber washers to use with these fittings?
Do I need to buy any putty or PTFE tape? (The top fitting has some old putty on it)
Is it possible to downsize them to 22mm along this stretch as it's easier to get a hold of 22mm pipe?
And obviously I need the actual fittings.
Thanks!
Thanks!
