Neighbours overflow Pipe leaking constantly
23 Nov 2005
Aberdeen
Hi all
My neighbours overflow pipe is constantly dripping and getting worse more flowing at times :mad:
now hes a bit weird\ bit of a ***** so i doubt he would pay for it to be fixed(been like this for about 6 weeks)
Im concerned at how close the water is dripping near my property :mad:
How should i diplomatically ask him to sort it ?
Could it get worse if he leaves it unrepaired ?
Could it not cause subsidence\illness ?
whats the likely fault cost and repair cost ?
could the local council force him to take action if diplomacy fails ?
Thanks in advance and i have to say this is great forum :)
Inform your local water authority, fines can be implemented for water waste.
u have to approach him and ask...for a start...then see how u go from there.
if its a lot of water...yes it can soften the ground below and cause movement..specially if house is just build on clay
it will be a ball valve....price from £35 - £90 ?...depending on access/plumber/area/
And if the water is dripping onto a wall, you can expect (1) damp wall (2) mould and algae (3) irremovable staining from hardened limescale that will look unsightly for a hundred years.
The valve only costs a few pounds and will probably be changed with half an hour's work - much the same as valve in a WC cistern (but due to its position in a dark and cramped loft often easier to fit a new one than change the washer. I then like to clean off the old one, fit a new washer, and hang it next to the tank ready for next time :wink:
victor meldrew said:
JPC said:
put a cork in the end...he'll soon sort it then ! :twisted:
Id like to kick the cork up his manhole :)
In Inverness, on a cold night, the overflow may well freeze solid, then it'll leak through his celing :lol:
Wait until all the water freezes and he busts his arse slipping on it...
Apart from the ball valve bit, it could be that the coil in his cylinder has a pin hole and the water level in F&E and CWSC are trying to level with each other... if this is the case his hot water could be a bit 'black' with black crap from heating system...
