- Joined
- 10 May 2021
- Messages
- 8
- Reaction score
- 3
- Country
Hi Everyone,
I have replaced my existing Myson MEP2C with a Nest 3rd Gen. Everything went well, except there seems to be no power to the existing stat where I was planning on hard wiring the new Nest thermostat.
Here is the wiring setup before at the conrol where:
3 = HW on
4 = CH on
Here is my new wiring. The three N and L have gone into two different terminal blocks and come out as one wire each going into the Nest's N and L feeds
Links between L > 2 (Common) > 5 (Common)
Going into the existing stat, I have a brown wire (should go to most right terminal), black wire with brown sleeve and grey wire with blue sleeve (should go to most left terminal).
Below is the wiring behind the control which is a bit hard to see.
The white cable to the right goes to the boiler.
The only grey wire coming into this box is coming from the second grey cable which is grey wire sleeved blue. This wire going into a terminal block with other neutral wires and then connects to the N of the Nest
The live browns go into a terminal block and connects to the L of the Nest
The black wire into the terminal block goes to call for HW
The brown wire into the terminal block goes to call for CH
Anyone have any ideas why the stat has no power? To be honest, I can't work out which wire is which!
Thanks in advance for the help!
3 = HW on
4 = CH on
