Hello Forum Members,
I bought a house in January 2013. The house was sold to me by a "professional developer" who had done a number of works to the house including fitting a new boiler, new radiators and new plumbing for the central heating.
As part of the conveyancing process our solicitor asked for and received a Gas Safe certificate. The business and the engineer listed on the certificate were/are registered in the Gas Safe register.
We have been having some boiler issues for a few weeks (see my post here). I had a plumber / boiler installer (with a great reputation on CheckATrade) come in to take a look. This good boiler installer told me that the works did not comply with regulations on a number of major points.
Some of the issues that he pointed out are:
1. Boiler had not been properly commissioned and had just been switched on after installation.
2. TRVs had not been fit on any of the radiators.
3. Condensate pipe was not of the right gauge.
4. Condensate pipe had not been drained into a soakaway or a drain.
5. The hole where the flue pipe was routed through the brick wall to the outside of the house had not been filled in / sealed.
He also remarked that the boiler was a cheap, low-quality one to begin with and was in most likelihood quite damaged because the central heating had not been flushed nor a filter put in.
Irrespective of whether I get a new boiler or not this is going to be a very expensive fix for me.
Have any of you been in this situation? Do you have any advice on how I should proceed? Specifically do I have any legal recourse against the original installer who effectively committed fraud to get the Gas Safe certificate?
Thanks.
Thanks.
