Hi everyone,
I have had an independent survey carried out to replace my current 30+ year old boiler. It is a Y plan system, with 10mm radiator piping and 6 radiators. It is controlled by a Hive system. The only hot water usage is for a bathroom and kitchen sink, we have an electric shower - no bath, with two of us in a 3 bed terrace property.
They have recommended a system boiler with weather compensation controls, still using the existing hot water cylinder. At present we only have the hot water heating on for one hour in the morning, and half hour in the afternoon to top it up, which is more than adequate for our needs.
The engineer I am using has recommended that the heating system will require changing to a sealed system this will require removal of heating expansion tanks. And changing of relevant pipework and incorporating a filling loop for self filling the new system.
The vented header tanks for hot water will stay in and will not be touched. However the coil from the cylinder will be re-routed to work directly from the boiler. Which will require pipes to run from current boiler position to cylinder. Provided a suitable route is achievable. A new 11kw system boiler will be fitted in the current boilers position.
Once this is completed the system will then be an X plan set up (priority hot water) a hot water sensor will be run from boiler position to cylinder. Meaning the hot water can be controlled via boiler user interface.
Weather compensation shall be introduced for better efficiency.
This plan may require quite a bit of upheaval inside the house to run the new pipes to the cylinder, including maybe lifting the bathroom floorboards, which are obviously under the bathroom fittings. I'm not sure I want to go through that sort of upheaval which will involve new bathroom flooring, and ceiling where the boiler is located. I am going to ask the engineer about this on his next visit, but would just like to have some knowledge about priority hot water, and whether I really need it before my discussion with him, so I can understand when he talks about it. I am a retired engineer, not heating, but can grasp most technical things, qualified in electric/electronics, and have a basic understanding of domestic heating system, I fitted the Hive myself.
The cost is not an issue, although it is expensive, just want to make sure I'm getting what I need. I probably won't recoup the cost in my lifetime, but I'd still like to pay less for gas than I am now, my current boiler is inefficient (original efficiency when new 60%) and quite heavy on gas ! Thanks for any insights into this.
