i have an old flat that needs its whole central heating system changed (for various reasons - including a cracked cylinder!). It is currently a standard gas boiler with a hot water cylinder. i want to change this to a condensing boiler to eliminate the cylinder altogether (to get greater storage in the flat).
The boiler is currently in the kitchen and the cylinder in a cupboard a few rooms away. The boiler currently has a cold feed (from a header tank i think) and a hot output to the cylinder.
To change it to a condensing boiler - i need some help. i am planning on doing all the pipes myself (with a competent plumber) and then get a corgi registered plumber to come in a connect it to the gas.
So here are my questions:
1) Is it possible to get a corgi guy to come in just to connect it? i have heard it is - but i thought i'd double check
2) any reccomendations on boilers to get under £1000? it's a 2 bedroom flat
3) i assume i need to pipe in a cold mains feed, have a hot 'mains' out and have a central heating mains in and a central heating out. Anything else i should be aware of - particularly when it comes to the flue and overflow (if any)?
Thankyou in advance and i really appreciate speedy replies!
Chris
Chris
