, hence any significant 'transparency' underlying the basis for the very wide-ranging change to BS7671. Does anyone know whether there is any real 'hard data' available anywhere?
Probably not. Even if there is, none of it will justify the use of metal or other non-combustible consumer units.
Of the data that is available:
a. The number of fires reported in the Greater London area involving consumer units in dwellings increased around 2012/2013 from a small number to a slightly larger number. About 250 per year or 5 per week appears to be the most widely available figure.
However, a couple of hundred fires a year in an area containing several million dwellings is statistically insignificant.
b. The actual cause of those fires was not published. There are many possible causes including defective MCBs, defective terminals, loose terminals, incorrect installation, tampering by various persons, etc.
c. The age of the electrical equipment involved in the fires was not mentioned. Neither were the specific brands or types of consumer unit, who installed them or what type of property they were in.
As for plastic consumer units and their locations:
1. Plastic consumer units have been available for decades.
2. Consumer units have been installed under the stairs and in exit routes since electricity was available.
The real point:
While the Brigade is pleased with this expected change it is still concerned about the badly installed fuse boxes in London’s homes.
Attempting to contain a fire is very different from preventing the fire in the first place.
