New electric heating for small terraced house
11 May 2007
Powys
We have recently bought a small end of terrace cottage in rural Shropshire. All room sizes are small, and I have been considering Dimplex DuoHeat electric radiators as the means to heat the property. This system employs an Economy 10 meter which uses 3 bands of off-peak electricity and two tarrifs.
Is this the best system to go for, or are there other alternatives which use electricity and bearing in mind space is limited?
How is the water heated, is there only electricity at the property?
Is there any heating at the house already?
To be honest with you, as an electrician, I would never fit electric heating unless there was no other option, the heat level is rubbish and the running costs are high.
You would be better having gas central heating installed, provides good heat more economically, is attractive to potential clients when renting. Also many people do not realise you shouldn't hang clothes on electric heaters, so they may end up breaking the heaters or even worse causing a fire!!!!!
Shropshire is a very rural county - no gas to be had for miles around guys, only Calor or LPG.
Currently its an all electric property, small rooms, open fire in the lounge. We are thinking of installing a wood burner in the lounge, and looking at the Dimplex Duoheat for the upstairs rooms. Agree electricity is not the best option, but as the house is so small I was hoping that the Duoheat units running on Economy 10 would not work out too expensive.
would it be possible to install a wood/pellet burner with a C/H & H/W built in, then use the electrics as backups or top up during milder weather??
Some clients of mine did just that but they are retired and can spend all day keeping the fire going and foraging for logs etc.
It works well for them but it means plumbing in rads.
it means plumbing in rads, but works well, even if you work, just needs to be kept lit over winter using a combination of dry and damp pellets/ blocks it can be kept at a low smoulder for well over 12 hrs, then just open up the air vents, throw on some fresh, dry fuel, and its roaring in a couple of minutes.
