New Gas Boiler!
1 May 2008
Norfolk
Looks like my friend's gas boiler might be kaputt!
What make of replacement boiler (Condensing/Combi) do Forum members recommend as a replacent?
Alan
Personally I think they're all cr*p. Built to the lowest permissible standards with the highest possible prices for replacement parts. Therefore choose the cheapest brand that you can get a reputable firm to install and look after.
Yep go with Tibbot , boilers with built in obscelecence , manus with a 100 % mark up on spares most of em do not make !
Personally I would go for a Wolf boiler , never fitted one but they are fitted in the Kremlin think about it OP minus 50 in moscow boiler packs up people die , next thing u know the KGB turn up around the installers house he is carted off 240 volts on his nuts , before they execute him !
Would u run the risk .No neither would the installer
so they must be reliable good enough for Putin good enough for you I say :)
Main buget boiler proven design and baxi are cheaper for parts than most
ie PCB and another componant failing on a vokera and its beyond economical repair!
seems broag boilers are well liked with installers i know.
there is no fit and forget boilers around now,to service most newer band A boilers requires a flue gas machine and possibly a gasket kit = mucho more pounds to service.
have seen many posts here that the system has to be very clean for the new boiler to work.
so the boiler can be reasonably priced but installation will be expensive.ie cleaning,cleaning and more cleaning.
good luck.
viessmann boilers are very good easy installs, very spacious, good technical support, 5 year warranty, price might let you down a bit, went on a course to viessmann 10/10.
