New loft hatch
4 Feb 2007
Denbighshire
I want to insulate and board out my loftspace in a 1930's ex-council semi. I would like to be able to use it as light storage and an occasional hobby room.
The existing loft hatch opens up directly beneath on of the supporting beams (purlins?) and the sloped section of roof which leaves approx. 800mm clearance in which I have to perform an excentric commando roll in order to get into the loft! :? It is also situated above the 1'st floor landing and stairs which means if i slip, I'm on a rather speedy, one-way trip to the ground floor!
I would like to move the hatch to a more cental position that alows greater head clearance for access. Is it just a case of cutting the hole in the ceiling, cutting through a ceiling joist, fitting a noggin between the joists either side of the hole (trimmer?) and making the hatch fame?
Also, do BCO need to get involved ant any point? I'm already having sleepless nights about them re: my other post in 'Building'.
Yes providing the roof are not gang nail trusses then put in another joist to make a double joists on the long length all the way and screw it to the ex-joist.
