New oil pump after running out of oil
5 Mar 2021
Recently my oil tank ran out of oil and when I got the tank refilled the boiler wouldn't start so my landlord sent around a plumber who supplied and installed a new oil pump and bleed oil to fix the issue. My landlord is now giving me a bill for £145.32, I have 2 questions
1. Can running out of oil cause this issue?
2. The boiler was recently serviced, should the potential failure of the pump have been noticed?
Thanks for your help
If the lock out button is repeatedly pressed then yes, the pump can wear as it requires kerosine for its own lubrication. Only a couple of resets are recommended.
If the pump was performing well before then it would do so again - so long as it wasn’t run dry. Without knowing the exact situation its impossible to comment further.
John :)
1 Yes
2 No, a service won't identify whether you're keeping an eye on your oil levels or not
Thanks both for your help.
I was asking if the service would spot an issue with the pump, I understand the lack of oil was my stupidity
Pumps can go at any time I’ve seen loads which have failed through running out of oil. Bob
Think you'll be stuck with the bill on this one, think yourself lucky the bill wasn't a lot bigger- the running out of oil gave the landlord the opportunity to renew the boiler at your expense. Don't do it again.
