New Part P Test equipment
Two problems.
Non RCD trip resolution is only 1 ohm.
Leads are very long so easy to tangle - however this can be a godsend on some locations.
Otherwise nice machine to use and tests earth rods/soil resistivity too.
In fact you can use one of the long leads with the earth spike kit as a wander lead for R2 tests as well.
The banana plugs on the end of the plugtop lead also make it a doddle to check using the Ph to N and Ph to cpc crossover tests on existing rings too.
You can save results and display them later and/or download onto your computer to print out.
If you do buy it then buy the strap kit as well
