- Joined
- 31 May 2007
- Messages
- 369
- Reaction score
- 0
- Country
Hello ppl and Merry xmas!
I have a couple of tilers/plumbers in who are going to be giving me a new bathroom.
I wanted to ask a few questions regarding this.
Firstly the old tiles that are removed are going to leave the walls uneven, they want to use aquapanel around the wet areas i.e bath sink and use standard 12mm plasterboard for the rest. Can I use 9mm? I was more inclined towards rendering the walls, with a cement mix around the wet areas. Is it better to drywall it all or should I tell them to render? They are also going to be dot and dabbing the boards to the walls.
The second issue is that the floor currently has floorboards, I am going to install underfloor heating cables and they are saying to board over the floorboards with WBP ply but as thin as possible, I was inclined to use maybe 12mm or is it ok to use say 6mm?
There is also lead within the bathroom, I am going to remove the lead for the water feeds but leave the lead of the water drain pipe, should I remove it all creating more work or leave it?
Also any recommendations on adhesives for tiles? or grouts?
Thank you very much for your time
