New value BS1362 fuse
This is reminiscent of something that I watched on Fake Britain (on BBC1) with Matt Allwright the other day, and it had an item of counterfeit fuses being sold in a well-known discount store (Poundworld).
It was very interesting indeed, and I could reveal all that was featured on the programme, but go and watch it, it is well-worth viewing!
The link to the programme is: http://www.bbc.co.uk/iplayer/episode/b07tl838/fake-britain-series-7-episode-3
I was speechless afterwards!
Hope this helps,
Regards,
Andrew! :)
While undoubtly there there is a problem with these, The video of the exploding plug (which has been online for a few years now) from earlier tests is perhaps over dramatic. I would guess that its been tested pretty close to the rated 6kA breaking capacity and in isolation rather than with other protective devices in circuit. I would expect that with sub 1Ka PFC at the plugtop and with an upstream B32 breaker, its not going to be quite as spectacular as thst
Not really speculation. Fakes have to be made cheaper that the real thing. One cost saving is not fitting the means to quench the arc when the fuse wire ruptures. The explosive power comes not from the heat of the wire melting but from the much greater heat of the plasma arc in the metal vapour of the fuse wire. The most common way to quench the arc is to fill the cavity around the fuse wire with fine sand which prevents the plasma arc forming.
Although I agree that they are fairly cheap, these are not really 'fakes' in the usual sense (albeit they should not exist). In this particular case there is no "real thing" with which they are in competition.
Kind REgards, John
No, there are not 20A 1362's, but there are other legitimate products of identical construction (apart from the rating) to each other, but not to the fakes.
I'm pretty confident if you broke a fake fuse open, you would find it an empty tube with no sand inside. It probably will also have an inconsistent poor quality fuse element too.
Ebay page said:
Details about 10 Pcs AC 250V 20A 6mmx25mm BS1362 Cylindrical Ceramic Fuses Tube
Yet the end caps appear to have holes which ( I believe ) are not permitted BS1362 ( ejection of material when the fuse ruptures )
You do seem particularly argumentative this week.
If you printed a twenty five pound note, would it not be a fake?
The thread is about fuses, not more definitions.
Not in the sense that it was a counterfeit copy of something 'genuine'. In any event, I don't want more discussion about definitions of words ....
Indeed, and I was responding to bernard's speculation about the (probable) quality of these fuses. As he said, if they were 'counterfeit copies' in competition with a 'genuine product', then there would be incentive to cut corners in manufacture in order to achieve a competitive price for their product. However, my point was not about definitions, but was that if they are not in competition with any 'genuine product', then there is no pressure to get the production cost (hence retail price) down below that of some other product.
In fact, I imagine that if anyone was silly enough to want such an item (which is generally unavailable), they might well be prepared to pay a fair bit to get one from one of the few possible sources - maybe even enough to facilitate proper manufacture and testing. Of course, bernard is right that they probably are poorly manufactured (and subjected to little, if any, testing) - but no-one can be certain abou that unless they buy one, test and dissect it.
Kind Regards, John
There is a link above to the Fake Britain programme where they did open one and found no sand.
I did see that programme when it was broadcast, and remember that there was no sand - but, if I recall correctly, that was about 'fake copies' of fuses of ratings for which there were "genuine products" available - hence the incentive to minimise production costs to be competitive. As for these current ones, for which there are no 'genuine' alternatives, we'll see!
Kind Regards, John
I cannot see why it matters that they have "faked" a fuse that did not exist before this one came out.
Surely they will just copy any other 1362 fake fuse design but put a thicker fuse element in it.
I cannot see why it matters that they have "faked" a fuse that did not exist before this one came out. Surely they will just copy any other 1362 fake fuse design but put a thicker fuse element in it.
Sure. However, the point is that if they are making, say, 'fake' 13A fuses, they have to compete with countless 'legitimate' manufacturers of such fuses, and therefore will be very tempted to cut as many corners as possible to minimise their manufacturing (and testing, and QC) costs.
On the other hand, if they produce a 20A "BS1362" fuse, there is no legitimate competition that they are trying to 'undercut' in price, so those pressures/temptations will be less. Indeed, as I just wrote, someone who 'really wanted' a 20A BS1362-size fuse might well be prepared to pay a fair bit for one.
Kind Regards, John
