- Joined
- 31 Dec 2009
- Messages
- 107
- Reaction score
- 1
- Country
Had this problem before with a Drayton acl 3-way valve - the type that doesn't have the removable head. HW works but CH doesn't. Can force CH on by pushing the lever to the right to the CH setting. In the past, changing the motor has fixed this issue. This time it hasn't. I've checked the inputs - on the CH-only setting, white and grey inputs are both 230V, but the motor doesn't seem to be turning at all, or at least it's not turning the valve. Slightly worrying - I've checked the voltage supplied to the motor and it's only 70V ish. This voltage check was done with the motor in situ so I assume the check is valid. If it is indeed only 70V then I'm guessing that's why it won't turn the valve. There's a small vertical circuit board inside the housing but as I understand it it's pretty simple (a microswitch or two, a couple of resistors and maybe a diode) so I'm not sure why 230V input results in 70V to the motor unless something has blown. I don't know if there's a way to remove the board to examine it. So basically, I'm hoping for clues as to what's wrong, and whether my conclusion about the voltage is correct - and if so, why the drop. BTW, moving the lever manually takes a LOT of pushing - don't know if that's normal.
