Last night a noise suddenly started up whilst our heating was running. It sounds like rain falling onto a tin roof and is more or less constant. The heating had been on for over 5 hours and the noise started suddenly. The only thing we have done differently is to turn our room stat up from 20 to 22. In January we had a new boiler (Vaillant ecotec plus 428) fitted in our loft which replaced a baxi bermuda back boiler. We had a slight problem with "expansion" from where the new pipework in the loft went through the new holes to the airing cupboard which our heating engineer sorted out, but this is a different noise and seems to emanate from the airing cupboard where all the controls are.
I am fairly confident it is not the 3 port valve, but it is hard to isolate the noise. It can be heard in our lounge in what I believe is the old capped off pipework to the old boiler. And in the 2 bedrooms between the airing cupboard. I called our heating engineer this morning but he cannot get to me until possibly tonight or even tomorrow,(fortunately the heating is working albeit noisily). He suggested it may be air in the pump (it has to run at setting 3 to avoid the dreaded S53 code on the boiler) so my husband has bled all the radiators (no air) and vented the pump, (he says a little air and water came out) but when he switched the heating back on again he says the noise is the same.
Any ideas in case its something simple. My husbands a carpenter but unfortunately heating, plumbing and electrics are beyond him!
We havent been up in the loft as the boiler seems to be working ok as in providing heat and hot water and was pluming nicely when I left for work.
We have an open vent system with boiler, cold water storage and F & E tank in loft, "normal" hot water cylinder in airing cupboard, room stat in lounge, pump, 3 port valve, bypass thingy (thats a technical term) and programmer in airing cupboard.
The system was flushed and inhibitor added when the new boiler was installed and the water that came out the rads and pump was clean.
Finally (sorry to have gone on a bit) when the system fires up from cold, the noise doesnt kick in until its up to temperature so this morning I thought it was just a blip last night as the noise didnt start for about 30 mins, but then once we're up to temperature and it goes off via the room stat and then starts up again its instant noise as the system's still warm.
Many thanks for reading, Denise
